Generate beams from an autocad Structure file using Grasshopper connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-03-14 12:17 PM
Helle,
I'm exploring some advanced grasshopper usage,
i'm trying to automate the translation of a DWG structure file to a 3D model,
i suppose that i have a structure file ( DWG )
* Beams are represented with centerline + text that indicates beam section dimension,
i keep only centerline and text visible,
Select all text and import in grasshopper,
Select all centernlines and import in grasshopper,
Is there a way to match text with lines in grashopper ?
this may be usefull for big projects, to automate some work.
Thanks
Archicad 27
Windows 11 professional
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-05-19 12:12 PM
i'm doing the same work with you, i hope this will be helpfull
