‎2008-05-08
09:50 PM
- last edited on
‎2023-05-23
03:11 PM
by
Rubia Torres
‎2008-05-09 06:33 PM
‎2008-05-09 06:53 PM
‎2008-05-09 07:08 PM
‎2008-05-09 07:15 PM
‎2008-05-09 07:16 PM
‎2008-05-09 07:24 PM
‎2008-05-09 07:50 PM
‎2008-05-10 12:48 AM
Tobin wrote:You could do this with OBJECTiVE, which provides tools to rotate, split, and bend objects in 3D. It also enables you to place, rotate, bend, and cut objects directly in the section window, all of which are quite relevant this task. I quickly modelled an example by doing the following (referring to the attached image):
thanks for the tip, I just tried that but im not sure how you can get the framework to show, I was able to turn it into a geodesic glazed roof but there was no framework so didnt quite work. Do you know how to add in the framework like that in the photo i originally attached?
