We value your input!
Get retaining walls below 0'0" level to show up on site plan
Gus
Does anyone have a clue about how I can get retaining walls below 0'0" level to show up on the site plan which is on my 1st story level? They are currently "associated' with the 1st level as being on that level (even though they are below 0'0". I have also set them to "all relevant stories" and that doesn't seem to change anything. How do I get them to show up when they are below 0'-0"?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
4 REPLIES 4
Try Symbollic Cut or Outlines Only in floor plan display.
Gus
View Settings, Floor Plan Cut Plane Settings. Then adjust as needed.
Madison WI
You cannot have a negative FPCP.
Gus
You chose to "show down to" then chose "project zero"
Madison WI
