Ghost libraries emerge in TW-projects
Mats Knutsson
Pretty often an old library (that no one have loaded) show up in our TW-projects. It's always the same library and it comes from an older project. I wonder if anyone have experienced the same and knows about a fix?
/Br
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
Mats_Knutsson
Mentor
I got this answer from GS support (not much we can do about it):
This is an already known bug (DEF-8098). Normally AC doesn't copy the Embedded Library when Copy/Paste between Archicad instances, but in case of user defined materials, it brings it over to make sure no attributes are missing.
Workaround: Remove the MASTER_... gdl-s from the Embedded Library.
AC 25 SWE Full
12 REPLIES 12
Hello @Mats Knutsson,
Did you have a module linked to your Archicad file ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
Nope. The ghost libraries appear from something else...
AC 25 SWE Full
Aaron Bourgoin
Copy / Pasting from other files might be a culprit. It is in this office.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
We've discussed that and since it's so common we suspect this is not the case.
AC 25 SWE Full
I get libraries showing up when people paste 2d details into a file. Routinely.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
hmmm...odd...I'll check the 2D details...
AC 25 SWE Full
Thx. This was it! If I just copy a line and paste into another project I get the ghost libraries and attributes. This must be a deep bug somewhere!? I'll sent it to GS.
AC 25 SWE Full
Mats_Knutsson
Mentor
AC 25 SWE Full
Mats,
We now have a Bug Number. Perhaps all who are affected can start contacting their GS support team referencing the bug and asking when the fix can be expected. We've suffered from this problem for eternity.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
