Graphic override - layer combination problem
I would just like to check if I am doing something wrong here before I report this as a bug.
I am trying to set up a rule that changes the pen colour of an object when a certain layer combination is turned on.
But no matter what layer combination I have set, the colour is still overridden (see attached image).
Am I barking up the wrong tree in expecting this to work?
10 Replies 10
Yes it can be done by filtering in other ways but the layer combination would be very simple for my situation.
What I have is a floor waste object that is shown on our floor plans.
But for our electrical plans it is not really necessary so I would like to hide it.
Yes I could create a new layer, put the floor waste in that layer and update the layer combinations - but I am talking about 100s if not 1000s of existing jobs (project home builder).
Using the layer combination in the graphic override would mean simply importing an amended GO (or just adding a new rule) that makes the object white when ever the electrical layer combination is active.
Same object, same layers, same layer combinations - just a tweak to add a new rule to the existing GO combination.
What I am resorting to now is a new rule to filter the object by name.
However this means that I also have to create a new GO combination and apply it to my electrical plan views.
So a little more work.
Just trying to simplify it as much as possible and not confuse or create too much work for our 60+ users.
