Slab Angle Representation 2D Problem
Hi all
I have some slab representation problems, wen i add angle to the slab edge, the 2D representation is incorrect but the 3D its good !
The attached image show the correct 2D with the manual red lines.
Do you any solution to fix this representation problem in 2D?
Best Regards
3 Replies 3
DGSketcher
Legend
If you need to keep it as a slab there doesn't seem to be an easy option. If you can convert it to a morph it will display as you want.
You could also add a (wall / beam) profile to the edge of the slab as another work around.
Tanks for your help !
My archicad 15 version dont have morph, and the beam profile have the same problem of 2D representation :C
Regards
If you don't mind using a different tool then a flat (zero pitch) roof will show the angled sides in plan.
So long as you have true 3D projection turned on for roofs in the project preferences.
In 15 I think the roof is the only tool that has the option for a true 3D top view projection in plan.
All other tools show only a representation of the top surface.
Slanted walls and columns will also show correctly.
