Green Objects
hi guys
im having problems my objects appear green.
how to solve thanks
6 Replies 6
In what view? Plan, 3D, ?
All objects?
All the time?
Could be, you are selecting with marquee, and aren't aware of it.
Marquee can be trouble if you don't pay attention to it.
Snap
If in Plan View could be that you activate Trace Refference. Press ALT+F2 to deactivate it.
Ralph Wessel
how to solve thanks
Perhaps the Floor Plan Display or Model settings are doing this (see the attached images). You can override the pen/material defined by the object to force the setting of your choice. Perhaps the object tool settings are set to override the object with a green pen or material?
Ralph Wessel BArch
Central Innovation
IN 3D IT happens to all the libraries that i have even with the internal.
Ralph Wessel
Can you confirm that Use Object's Materials is checked under the Model tab in the Object Settings dialog?
Ralph Wessel BArch
Central Innovation
Thanks a lot it worked
Can any body help me cannot post pics i adjust all the parameters but appears an error messages.
