Arcadia
Gripe about guidelines and guidelines etc
I often use the 1/2 or division snap points. On all versions of AC I have found that the little marker that comes up on the element you want to snap too is REALLY faint and small. I haven't found a way to customize this. Why can't it be a flashing red box or something so we can actually see it? This is made even worse in V15 as now whenever you try and hover the curser over a midpoint the bloody guidelines circle/handle pops up - usually right where the midpoint marker is.
Does anyone from Archicad actually use this software?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
David Maudlin
You can change the color, see Work Environment > On-Screen Options > Special Snap Point color.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Arcadia
The marker is so small and faint the colour doesn't really make any differences to its visibility.
