We value your input!
Ground rendering
Eman
When I try to render with Internal engine I don't know how to insert a ground image. I can only insert a sky image as the picture.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
It is not specifically a Sky image; it is simply a background image.
If you select the "Colors" option in the "Background" field then you can select a color for both the sky and the ground, but not images for both.
Hi Laszlo Nagy and thanks very much.
Eman / Draftsman
