KeesW
Grouping
Why does AC18 default to 'grouping'? I find this a lot when I know that I haven't consciously chosen this option. Or is it linked to another activity?
I've now imported a drawing from AC17 to AC18 and find whole portions grouped - and cannot find where to ungroup them. GGGRRRRR!
Moving a project from one version to another is a nightmare.
Cornelis (Kees) Wegman
cornelis wegman architects
4 Replies 4
are you saing that menu edit->grouping->ungroup doesn't work?
David Maudlin
KeesW:
Make sure the command Autogroup is not checked (this works when elements are created).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
KeesW
Thanks David.
Are you saying that 'Autogroup' is automatically selected when elements are created? If so, why?
David Maudlin
Kees:
I don't know what the default Autogroup setting is, just that you should not have it checked (active) if you don't want elements grouped when created. I prefer elements grouped (linked Walls, Beams, Lines), then Suspend Groups when editing individual elements.
David
