Guastavino Vault
How would I model a guastavino vault?
I know roughly how to create the simple barrel vaults, however I'd like to be able to create a kind of roof structure which curves down to the ground/columns.
Thanks.
22 REPLIES 22
Mesh generator is your answer...
Is it possible with the Shell tool?
Anyone?
Erwin Edel
Probably not with a single shell, but perhaps by combining multiple shells into the one shape.
http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=...
good starting point?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I think that archicad can“t do that... maybe other better program like Revit
Sorry but the curtain wall doesnt fit with the vault ... more haste, less speed
No more than 10 minutes, archicad + artlantis include.
Cinema 4D plug connection to ArchiCAD in will do the job pretty easy.
Thanks for all the response.
I think Revit would be easily able to create my vaults. Unfortunately, it seems ArchiCad isn't quite capable at this point.
But if I was to create my vaults in Revit, would I take it back in to ArchiCad as an object?
Thanks
Thanks.
Try this exercise with OBJECTiVE. I made the attached image in a few minutes using its profiling, bending, and cutting tools.
Ralph Wessel BArch
Central Innovation
With archiforma and the "Coons Surface" is a smart way to do too.
