Guide lines
Hi
How do I get in plan view the X and the Y axises to show has guidelines?
I also wonder how I can get The X,Y,Z axises to always wo up in 3D view.
Sometime i need to move big projects to reference point and it is much better to do that in 3D.
14 Replies 14
Stress Co_
Not exactly "guidelines", but is this what your after?
Scroll down to Peter Clark's Post.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Hi
No
that parameter is just ferry hard to work with.
I remember on my last office i did have y and X gide lines but I cant find tha now in this ofice.
Do you mean the grid display?
Shift+G is the default shortcut.
Hi
I need all the poosible guidelines to show.
No I onely get one 45 angle guide line. before I use to get the X and Y + a lot of other good stuff like paralles and so one.
What am I doing wrong?
Ah you don't get to see all the guidelines at once any more - not since version 15 when they changed.
You have to activate the guidelines and then select the one you want.
Here is one post I found that talks about the 'new' method.
http://archicad-talk.graphisoft.com/viewtopic.php?t=37976
Also look in the reference manual and on-line help.
0046247
Borrowing the thread:
Is it possible to have the guide lines i've made visible all the time? As for now they disappear as soon as i draw, rotate or paste something etc. I want them to show even after an operation. Been drawing a lot in sketchup lately and been using the guide lines there frequently and gotten used to it.
No unfortunately the guidelines will delete once you have completed a command.
The only way you can do it is to have a layer that you can turn on/off as needed and place actual lines in it for your guides.
Make a wish in the wish section and you never no what might happen in future.
