‎2021-01-27 09:35 AM
‎2021-01-27 10:15 AM
Draw wrote:
Since 23 and now in ArchiCAD 24, the guideline handle takes very long to appear, takes up to 11 seconds. Very frustrating if want to move a guide quickly to new position. I'm at a stage where I delete the guide and draw a new one. Anybody else experiencing this? Is there a setting somewhere or a fix?
‎2021-01-27 11:27 AM
‎2021-01-27 12:08 PM
‎2021-01-28 02:13 AM
Draw wrote:
Found the glitch. If I load the ArchiCAD 24 standard profile, it works like it should. If I load my custom profile with menus where I want them, shortcuts, etc. it has the delay. So I will try and recreate my Work Environment from scratch and see if that still works when I'm done. What a pain....
And I found the culprit. I forgot to mention my Dual Screen Setup. As soon as I open the Window Palettes "Organizer" and move it to the second screen, the delay incurs! Can someone recreate this?
‎2021-02-01 01:06 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-04-06 07:33 PM
‎2021-04-06 10:06 PM
‎2022-01-05 05:14 PM - edited ‎2022-01-05 05:15 PM
Same problem here. It's tedious and frustrating. In some cases it just doesn't show up, so I can't move the guideline around.
‎2022-01-07 11:18 AM
Can it be that you have Snap Guides on also? This causes that a blue line shows first, then along wait, and then comes the orange ball. Turn off snap guides.
