HELP Menu activates Ineternet Explorer POP-UP BLOCKER
Each time I select ArchiCAD's HELP command it tries to open a window using Internet Explorer. The window is stopped from opening by IE's POP-UP Blocker.
I tried adding the HELP screens address (C:\Program Files\Graphisoft\ArchiCAD 9\Help\ArchiCAD\Files\index.html) to the sites that IE's POP-UP Blocker would allow but IE does not let me add a site that does not start with HTTP.
I do want to leave IE's POP-UP Blocker on so that it blocks other site's POP-UPs.
How is IE supposed to be confiquered so that ArchiCAD's HELP menu opens easily in IE without being stopped by IE's POP-UP Blocker?
THank you,
John
16 REPLIES 16
Right click on the message bar and select the option to allow the window to open. You will need to do this on a case by case basis but it is very straight forward. As I understand it, ArchiCAD help uses ActiveX content and that triggers the response.
Aaron Bourgoin
How might I coax the Help System to select Firefox and not Explorer. IE doesn't seem to let me yell it that AC Help System is not going to infest my computer with worms. Firefox seems to give me the option of declaring this once and then getting on with it for evermore.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-6000 USA
Rhino 8 Mac
MacOS 14.6.1
It works with opera too....
Is there any way to shut off IE's POP-UP Blocker warning for the ArchiCAD Help window and still have the POP-UP Blocker active?
Thanks,
John
You'd have to set Firefox as your default browser.. Which it should be anyway!!!!
HTH,
Daniel
Thanks,
John
Im not 100% sure but this might work: open IE, select Tools->Internet Options, Select the "Privacy" Tab, and click the "sites" button, then add the path to the archicad help file to your trusted sites list.
HTH,
daniel
Daniel wrote:
I'm not 100% sure but this might work: open IE, select Tools->Internet Options, Select the "Privacy" Tab, and click the "sites" button, then add the path to the archicad help file to your trusted sites list.
HTH,
daniel
Daniel,
If I try to past the URL (C:\Program Files\Graphisoft\ArchiCAD 9\Help\ArchiCAD\Files\index.html) for ArchiCAD's Help Menu into the window to allow sites in the PRivacy tab I get an error message. The error message reads:
Invalid Domain
You have entered as invalid domain. Domains must be in the Internet zone and must use the HTTP of HTTPS protocol.
Examples of vavild domains:
-www.treyresearch.com
-http://treyresearch.com
-fineartschool.net
I feel that if this is a problem for all ArchiCAD users using Internet Explorer that Graphisoft should look into a solution.
Thank you,
John
Aaron Bourgoin
Firefox is my default browser. The AC Help system launches IE.
Rhino 8 Mac
MacOS 14.6.1
Same here. Firefox is default browser, but for some reason ArchiCAD Help always opens in Internet Explorer.
