Mickey,
It's not ridiculous.  You can create a publisher set of modules, one for each story. Bring each story in, and easiest done in the section window, adjust the vertical alignment of each story.  You only need to do this once for each building.  If you have multiple instances of one of the modules, drag a copy of the vertically adjusted one to its location.
The initial set up may take an hour or so for the dozen buildings, but after that all you need do is update the modules.
You probably could have done this in the time it took to whine
I'm looking forward to a screen shot of your site with all the buildings.
	Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
