ā2009-06-24 04:36 PM
ā2009-07-03 06:06 PM
Jere wrote:I never have liked the library part... I just use linetypes. I can't remember if these are built in to AC or if I built them myself, since I've been using them since AC6.5 or so.
The more I see of your drawings, the more i'm tempted to use the insulation fill. Normally i'll just draw the insulation using the library part.
ā2009-07-03 07:31 PM
Jere wrote:Strangely, I had never thought of using complex profiles for ordinary 2x frame walls... I just use the old fashioned wall tool. Are people regularly doing this with success? I could see some hiccups at rake walls, etc. But otherwise it would seem to be a smart approach. Any links to relevant threads on this topic?
Couldn't you just incorporate that into the complex profile or are the exterior walls just composites?
ā2009-07-09 10:36 AM
ā2009-07-09 02:09 PM
KeesW wrote:I would love to see some example sections/elevations.
Will send more info, including examples, if people are interested.
ā2009-07-09 03:08 PM
Steven wrote:Same here.KeesW wrote:I would love to see some example sections/elevations.
ā2009-07-09 08:22 PM
ā2009-07-14 10:49 AM
ā2009-07-14 10:50 AM
ā2009-07-14 05:42 PM
kliment wrote:Great drawings Kliment! Thank you for sharing.
I model 90% of the building, so when I have to make changes it is faster.
ā2009-07-16 11:16 PM
Rick wrote:My (2 person firm) approach is to keep elevations live with a little bit of 2D line work.
Basically, with a few additives:) This is an auto generated section, and the only things added are white fills for the plates and rim joist in section.. and some, but not all, insulation fill.
