HOW TO MERGE FILLS
Is there a way to combine two fills that are touching into one fill?
7 REPLIES 7
Erich
You can use the consolidate fill command, however, I typically just select one of the fills, set the fill tool active, magic wand the other fill, then delete the second fill once the first has expanded to match the second.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
I think you still have to do a:
Edit>Reshape>Fill consolidation if you don't want a line between them, even after using Erich's method.
At least that's how it seems to work for me. Maybe I'm missing something?
Then you also might want to move the old joining nodes to corners, but that should not effect display of fill.
lec
David Maudlin
I think what Erich is referring to is to select the Add to Polygon option (polygon with + icon) in the pet palette after clicking on the edge of the selected fill.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erich
David,
You are right, I forgot the critical step since I just do this on autopilot...
Lec, you need to delete the old fill that you matched once you are finished. Then you do not have a line between the two.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Hi Erich
Maybe since I'm new to your method, I still get line between the two fills even after deleting the fill that was converted.
Below before consolidation but old fill deleted.
See next post for after fill consolidation.
lec
After fill consolidation.
Reread Davids remark,
Ok I get it now.
Thanks all.
lec
