‎2006-06-11 03:02 PM
‎2006-06-11 06:03 PM
‎2006-06-11 09:50 PM
Matthew wrote:im using zone_stamp_0210 archicad 10
You mean in the zone stamp I assume. This depends on the specific stamp you are using. Try different ones to see if they will do what you want. No one will be able to answer you more specifically without knowing which stamp you are using.
‎2006-06-12 02:44 AM
NeckoFromSarajevo wrote:We don't have that stamp in the US so I can't check it here. I assume you have looked at the stamp's parameter settings. If not, you can check the individual settings in the zone settings dialog. You can also reset the default settings for the zone type in the attribute settings for the zone categories.
Area is in meters and thats ok
but perimeter is in cm. I dont want cm i want that in meters
‎2006-06-12 10:53 AM
‎2006-06-12 04:10 PM
Link wrote:That is possible depending on how the stamp is scripted.
I thought the units for this was set by the 'Length Unit' setting at Options > Project Preferences > Calculation Units...
I don't know why this would change on it's own though?It shouldn't. I am not sure what is happening in this case though.![]()
‎2006-06-12 09:38 PM
Matthew wrote:Link wrote:That is possible depending on how the stamp is scripted.
‎2006-06-13 05:47 AM
NeckoFromSarajevo wrote:Change your working units to meters.
I checked everthing and i just cant get perimater units in meters, they are now in cm. How i can change this. This is in zone tool.
HELP PLZ
