‎2006-06-10
02:01 AM
- last edited on
‎2023-05-23
05:15 PM
by
Rubia Torres
‎2006-06-10 02:39 AM
‎2006-06-10 05:20 AM
NOELDESIGNS wrote:When you select soemthing else, right click and choose "show selection in 3D"
In AC 10, when I click on a wall (example, could be anything), and click on the 3D button, the entire model shows in 3D, not just the highlighted object, wall, etc.
I can right click on the selection, and choose "Show selection/marque in 3D" and it works.
However, when I close down 3D and highlight something else entirely different, the previous selection shows in 3D again, not what was selected.
Are these bugs or am I using AC 10 incorrectly?
Thanks,
Grant
‎2006-06-10 01:04 PM
‎2006-06-10 01:07 PM
Matthew wrote:matthew - it is, in fact, how it was 'deisgned' (i use the term loosely) to work in ten. because of the ability to creat multi-story elements, the whole 3D window opening logic needed addressing. unfortunately, graphisoft took the scissors and cellotape approach rather than implementing something that was intuitive and logical. only by using the 'Show Selection/Marquee in the 3D Window' command is the old behaviour (kind of) replicated . . .
The behavior you describe is not how it is supposed to work. My 3D window changes to show the new selection as it should. I don't know why this works for me and not for you.
‎2006-06-10 05:29 PM
‎2006-06-10 05:52 PM
~/archiben wrote:Ben,Matthew wrote:matthew - it is, in fact, how it was 'deisgned' (i use the term loosely) to work in ten. because of the ability to creat multi-story elements, the whole 3D window opening logic needed addressing. unfortunately, graphisoft took the scissors and cellotape approach rather than implementing something that was intuitive and logical. only by using the 'Show Selection/Marquee in the 3D Window' command is the old behaviour (kind of) replicated . . .
~/archiben
‎2006-06-10 07:45 PM
‎2006-06-11 02:28 AM
‎2006-06-11 02:30 AM
Matthew wrote:Quite so. And the effect of the command depends on what, if anything, is selected
It is a one-off command not a change of state.
Mabe wrote:This is not entirely correct. If there is no selection then Show Selection in 3D shows the entire model (same as Show All in 3D). After you make a selection (in plan or S/E) and then invoke Show Selection in 3D you are taken (of course) to the 3D window
This initially shows selected, but toggles between selected and the entire model, a very handy feature.
