Hatch inside splines
Paopao
I have difficluties to hatch areas between two splines. Is it a bug and how to I do it?
Thanks
Pao
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
Miha_M
For me it works with all border points properly closed into a polygon. If the area is without intersecting elements, then a "space" (magic wand) -click with the fill tool selected does the job. If you have other elements intersecting the polygon then you should have the border elements selected while magic wand-clicking in/or on the border.
But the fill shape is not a complete match, as Archicad seems to converts the spline into arc segments.
| Archicad 4.55 - 27
Paopao
Thanks!
