Having trouble with complex profiles
Hi there,
I'm trying to create a concave, irregular wall somewhat similar to this one:
I am fairly new to making complex profiles and am struggling. Any help would really be appreciated.
thanks.
19 Replies 19
it will automaticly rotate it to horizontal once you save it as an object.
go to 3d view and setthe camera to be viewing it directly down like plan view before u save it
hmm just can't seem to do it.... I can get it to curve vertically and horizonatlly seperately. but i cant seem to get it to curve both vertically and horizontally if you know what i mean.. i must have missed a step somewhere. i'll keep mucking around with it and hopefully i'll find that missing step.
Erika Epstein
when you save it as an object, you need to be looking at in the 3D window as though you are looking straight down on it as it will be when placed.
Check the help menu
Put your Archicad version and OS in your signature please.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thanks for all the help, I really do appreciate it.. I've now been able to do everything but make the profile curve vertically. As you can see in the picture it's only curved horizontally.
David Maudlin
When drawing the wall, use one of the curved wall Geometry Methods so the wall is curved in plan (before being rotated when saved as an object), this should be slightly more than a semi circular shape in your case.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Ralph Wessel
Take a look at OBJECTiVE - it has tools for bending custom profile or built-in steel objects to complex curves in 3D. The objects retain their intelligence too, no matter how they are bent, rotated, or cut in 3D. I've attached some images to illustrate some uses of the tools. You can find out more at: http://www.encina.co.uk/objective.html
Modelling the building in the picture won't be easy - I could be wrong, but external envelope doesn't seem to be comprised of regular arcs, i.e. it looks egg-shaped.
Ralph Wessel BArch
Central Innovation
Dwight
You need to understand that a curvy-durvy wall must be converted into an arched structure by converting it into an object - this is how the orientation is changed.
Use the information here to do it:
http://www.archicad.ca/Downloads/DNC-Cookbook-4/Intro-to-Object-Making.pdf
page 14
Dwight Atkinson
cheers for that Dwight, helped a lot.
A new problem I'm now facing is that I cant figure out how to change my background from grey to white... If i select the complex profiles it changes my drawing area from white to grey, which only began happening today.. How can i change it back so it looks like it does in the second picture? I cant see any of the lines that i draw if it's grey even though they are there..
cheers.
Don't worry, I worked out how to fix it.
