‎2008-10-23 03:52 AM
‎2008-10-23 07:39 AM
‎2008-10-23 08:18 AM
‎2008-10-23 08:25 AM
‎2008-10-23 01:24 PM
‎2008-10-23 02:46 PM
willy684 wrote:When drawing the wall, use one of the curved wall Geometry Methods so the wall is curved in plan (before being rotated when saved as an object), this should be slightly more than a semi circular shape in your case.
I've now been able to do everything but make the profile curve vertically. As you can see in the picture it's only curved horizontally.
‎2008-10-23 06:49 PM
willy684 wrote:Take a look at OBJECTiVE - it has tools for bending custom profile or built-in steel objects to complex curves in 3D. The objects retain their intelligence too, no matter how they are bent, rotated, or cut in 3D. I've attached some images to illustrate some uses of the tools. You can find out more at:
thanks for all the help, I really do appreciate it.. I've now been able to do everything but make the profile curve vertically. As you can see in the picture it's only curved horizontally.
‎2008-10-24 12:48 AM
‎2008-10-24 02:13 AM
‎2008-10-27 06:37 AM
‎2008-10-27 07:36 AM
