‎2008-06-04 08:33 AM
‎2008-06-04 09:12 AM
sfoo wrote:Check where you have the elevation line positioned.
We're having some troubles with elevations in AC11. Sometimes they come out looking like sections where you have a section line with markers at both ends instead of a single marker in the middle with no "section line". This happens even when we use the Elevation tool to create a new elevation and it still comes out looking like a section line. It does appear under the Elevation tree though.
Since the tools were separated in AC11, I can't seem to find a way to change the look of elevation lines. Can anyone help?
Thanks!
‎2008-06-04 11:00 AM
‎2008-06-04 11:08 AM
sfoo wrote:I understand what you mean now - but I don't know why it is happening.
Thanks Barry, but I think you may have misunderstood me.
I'm not talking about the view you get when you open the elevation. Rather, I'm talking about what the marker and section line look like on plan.
In AC10 and prior, there was one tool and you could set the properties of that tool so that you either had:
- a section line with optional markers on either side of the line; or
- an elevation marker in the centre of a non-printing section line
In AC11 it got separated into two tools. Each tool was supposed to give the right look in plan and as far as I know there is no way to make section lines and markers look like an elevation marker on plan. That's ok I guess when it works, but right now my elevation markers look like section lines and I don't know how to change them in AC11...
‎2008-06-04 02:31 PM
