Help! How do I create niches in walls?
I'd like to create different niches in walls or cut out sections of walls altogether to allow some rays of sunlight to peek in. How can I break through parts of a wall?
10 REPLIES 10
Peter wrote:
The SEO is performed as a subtraction with upward extrusion
with the walls as target and the stairs as operator.
It seems that there may be something unusual in your case
since you are not getting SEO to work.
I use the SEO tool quite often, so I'm fairly familiar with it - BUT, I also have problems when trimming the walls under stairs.
The strange thing is it doesn't happen every time, and I can't find a common theme with the stairs that won't trim.
Does any body know if this is a known bug?
