Help Needed!!
Hello.
I want certain walls to show to the upper floor with a dashed line.
I have activated the "All Relevant Stories" and the cut plane adjusted to show 1 story down.
The overhead line is dashed.
I can see the wall but the line is not dashed. Is this a bug in Archicad 15?
Can anyone please describe the exact settings?
I also found out that the stairs in the story sensitive control even if the numbering is deactivated the numbers still appear at the above story so I guess this is a bug.
1 REPLY 1
Its not really a bug, but there is more than one place where you can set the cut plane.
if you have a "view maps" set up with different layer settings then you will need to update the Cut-plane interface box for those layer settings along with the universal cut-plane interface.
Try looking at the uncut line pen aswell.
As for the stairs, select "story sensitive" and turn it on, you'll then get an additional dialog line "2d above home storey" you cna turn numbering off in there.
Hope this helps
