Help, how to change case in zones
Hi all, I have a large project with many zones. I need to change the case in the zones from sentence case to capitals. Is there a way to select all the zones and make all the text capitals, without having to rewrite all text?
Thanks.
Not unless an option has been scripted into the zone stamp - you will find it in the stamp settings if it has.
But I would doubt it - I haven't seen to many objects with this option.
I can't say for sure without know what zone stamp you are using (and the version of Archicad).
vistasp
This won't work if you have standards to follow but one option is to load and use an all-caps font.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Post moved.
