Help importing DWG file-the scale is lost
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-08-18 07:27 AM
2005-08-18
07:27 AM
13 REPLIES 13
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-08-18 07:53 PM
2005-08-18
07:53 PM
Hello David
The way to choose the "scale" —in reality the "proportion" between your AutoCAD file and your ArchiCAD file— when you import your dwg file is set in the "Drawing Unit" Menu.
You choose 1mm for 1mm like your "2-dwg-translation.png" or another value —may be 10, 100 or 1000 mm, I think 100 in your case…—.
I don't know a way to know the good value before opening or merging the dwg file, you must try, cancel and adjust it anytime necessary.
Hope this Helps…
Hope this Helps…
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-08-18 10:36 PM
2005-08-18
10:36 PM
Frédéric, thanks, for your help, on the window: dxf-dwg Translation Setup, Settings in Selected Translator, Drawing Units, I change the value from 1mm to 1m, then on Set scale Factor: I´ve choosen, use constant factor for all convertions (this case 1:100), then save settings. And that´s it. It opened with scale 1:100, perfect.
thanks also for Link
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-08-18 10:39 PM
2005-08-18
10:39 PM
and the final result was complete, well done.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-08-19 07:09 AM
2005-08-19
07:09 AM
You should know beforehand, on top of what real world units the AutoCAD units are assumed to be, which scale the AutoCAD drawing was made FOR. Otherwise your text and annotation will go haywire.
The process is OK.
Make a note of the fact that you can set the scale BEFORE opening the DWG regardless of the scale set in ArchiCAD, OR use the scale set in ArchiCAD.
The process is OK.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
