Help making irregular ramp
Hello everyone:
Im trying to model the same irregular curved street from that image, but i just can`t do it .
Basically what i do is with the magic wand and the roof tool create a 2d figure, but in 3d the angles are always wrong (getting angles in different directions). Modifying the roof with morph helps, but the result is a messed up shape -_-.
What can i do?,
Thanks!.
Eduardo Rolon
Check if this helps. I would draw the street section as a custom profile for the Beam and I would split the beam at different known elevations.
http://archicad-talk.graphisoft.com/viewtopic.php?t=43075&highlight=morph
BTW very nice project.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
