Help me understand proper scale
I have a topographic map where 1.5cm is 25 meters, how can i transfer this into archicad to trace with accurate scale
7 Replies 7
Also so the height is correct, what units is the wiremesh elevation box measured in?
see i just made a mini map of a park then stuck a person on it and it was taller then any of the 30 meter high mountains
Petros Ioannou
If you placed a scanned image inside your drawing, you can draw a line (as much accurate as it can be) over this 1.5 cm dimension.
Then select this line and your image and "resize" them using this line as a guide. I usually draw a second parallel line next to the first one (with the correct length starting from the same point) just to use it as a reference when I scale. Although I have to mention that this is not the most accurate method you can use....
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Djordje
How do you have it? Image, vectorial file?
The ratio you gave is a 1:1666.67 scale; pretty funny, although there were scales like that used in olden times, for example Austro Hungarian Empire (had a scale rule once with funny scales ...)
If image, resize it. Make sure to set ArchiCAD to the same units the map is scaled to, and to use the same scale the map is scaled to; otherwise, giants or dwarves will happen ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hi Djordje thanks for the reply,
the map is in a .pdf file, i could convert it to an image but can you explain a bit more how to properly resize it, at the moment im marqueeing it in acrobat reader and copy paste into archicad. is there a better way?
Djordje
Not really; how do you know then that 1.5cm is 25m?
Resize what you pasted, and use that for reference. Work in meters. Set scale for whatever scale is marked on the map.
Good luck!
Djordje
HP Omen
Good luck!
i have an A2 hardcopy
