ā2004-04-27 02:38 AM
ā2004-04-27 05:35 AM
ā2004-04-27 05:54 AM
ā2004-04-27 08:53 AM
ā2004-04-27 10:59 AM
edd91 wrote:How do you have it? Image, vectorial file?
I have a topographic map where 1.5cm is 25 meters, how can i transfer this into archicad to trace with accurate scale
ā2004-04-27 11:06 AM
Djordje wrote:Hi Djordje thanks for the reply,edd91 wrote:How do you have it? Image, vectorial file?
The ratio you gave is a 1:1666.67 scale; pretty funny, although there were scales like that used in olden times, for example Austro Hungarian Empire (had a scale rule once with funny scales ...)
If image, resize it. Make sure to set ArchiCAD to the same units the map is scaled to, and to use the same scale the map is scaled to; otherwise, giants or dwarves will happen ...
ā2004-04-27 11:16 AM
edd91 wrote:Not really; how do you know then that 1.5cm is 25m?
the map is in a .pdf file, i could convert it to an image but can you explain a bit more how to properly resize it, at the moment im marqueeing it in acrobat reader and copy paste into archicad.
ā2004-04-27 11:30 AM
Djordje wrote:i have an A2 hardcopyedd91 wrote:Not really; how do you know then that 1.5cm is 25m?
Resize what you pasted, and use that for reference. Work in meters. Set scale for whatever scale is marked on the map.
Good luck!
