2021-06-22
10:12 PM
2023-05-09
03:42 PM
Rubia Torres
2021-06-23 02:02 AM
2021-06-23 03:42 AM
2021-06-23 05:25 PM
Barry wrote:
If the side of the slab and the edged of the wall are perfectly in line and they have the same surface setting, they should blend with no joining line.
If you still see a line, have a look at the layer intersection priority number for each layer (I am assuming the wall and slab are in separate layers).
They should be the same if you want them to join.
Or check that you do not have 'Legacy' mode on in the Options > Project Preferences >Legacy menu.
2021-06-24 03:20 AM
2021-06-24 04:36 AM
EH21 wrote:
Thanks, Barry. Is there a way to make the inside edge material different from the exterior? My problem is that on the outside, I want it to be siding, but when I create an opening in the floor on the interior, I don't see a way to make it the same material as the rest of the walls. Thanks again.
