ratnabhirud
Hiding Triangulated surfaces on Mesh
If I inserted .txt file through 'Direct import surveyers data' tool, it is directly converted into the Archicad Mesh having Triangulated surfaces.
Now I want to hide these so that I can see actual specific contour lines.
When I change the option present in 'Floor plan and section' tab of mesh,
only black nodes are visible.
Is there any solution for this?
Regards
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
4 Replies 4
vistasp
Mentor
Ratna, have you tried the contour maker gdl object in the depository?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
ratnabhirud
Thank you very much Vistasp.
Attaching image what I got from Contour Marker.
Only problem is Actual contours in Dwg file (orange color) are smooth curves and from Contour Marker (Blue color) are somewhat angular shape.
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
Djordje
Check your Magic wand settings if they are used to trace curves
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
ratnabhirud
This mesh is created with 'Contour Maker' and in this Contours are detected from input levels , option present in its dialog box , so is there any relation with Magic Wand?
Magic Wand was set to default.
Thanks & Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
