Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
Holes appearing in walls - Why
I've been using railing objects for the balconies with chrome poles between the glass panes then I decidet to delete and replace them with a wall object. The problem is that now there are holes in the walls at the places where the poles were. Is that a bug or it is me?
Here's a shot:
7 Replies 7
What happens when you select it? What is it? You can always patch it up
TomWaltz
Is it possible that there is still a pole there?
Tom Waltz
You must check double ojects.
No, there are no railing objects left overlaying the wall!
"What happens when you select it?"
Nothing special. What should happen?
"You can always patch it up "
I don't want to to save the area enclosed by the 2D Marquee as a parametric 2D Library element. Why patch it then? What do you mean?
TomWaltz
Any possibility that the one on the floor above is set to show on a story below?
Tom Waltz
If you can select it, it means there IS something there, whether it is on that storey, storey above showing one down, or storey below showing one above.
If you can't select it, it may be a column on a layer turned off. They still interact with walls.
a) "Nothing special" not a good answer to help you solve your problem
b) Don't patch it then..I was just trying to help
good luck
