‎2005-07-15 11:41 PM
‎2005-07-16 12:40 AM
‎2005-07-16 02:19 PM
‎2005-07-16 07:51 PM
‎2005-07-16 09:47 PM
Scott wrote:You beat me to the punch on the first part. I wanted to caution everyone that all of these other things are saved when you save a 3D view (axo or persp) as well. And it is not just the rendering engine, but ALL settings for that rendering engine. It also includes the 3D window settings (OpenGL settings, or internal/hidden line, transparency, etc.). Everything.
Related question; A view set of any 3D projection (axo or perspective) will remember the position of the sun and the rendering engine used. ... is there a way to have the sun object's azimuth automatically change when a different view set of a projection is selected?
‎2005-07-16 10:04 PM
‎2005-07-17 12:30 AM
Scott wrote:and to return to your question scott:
Q) Is there a way to automatically re-set the azimuth for these lighting sources based on a view set definition? In other words, is there a way to have the sun object's azimuth automatically change when a different view set of a projection is selected?
‎2005-07-17 12:45 AM
‎2005-07-17 12:48 AM
‎2005-07-17 01:12 AM
Dwight wrote:Yes. A royal pain. So, if you realize that a different set of rendering options, or sun settings, is what you really want, you have to bring up each camera or 'projection' and save a new view (or replace old).
It means saving a succession of new views based in the same camera location...... every time?
