Hotfix-5 for ArchiCAD 12 (build2675)
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Dear AC-Talkers,
Hotfix-5 is now available for INT, AUS, NZE, AUS localized versions of ArchiCAD 12. You can download the Hotfix through the Help menu/ Check for Updates command. You can find a list of fixed bugs in the Release Notes.
Gergely Kmethy
22 REPLIES 22
GS, thank you for the hotfix in the release
Bob wrote:
I attempted to install the Hot Fix 5 three times today and each time the installation failed. Has anyone else had this problem?
I finally got it downloaded, but it won't start. I keep getting a message that it's not a valid Win32 file <sigh>.
Wendy
Install was smooth, on 1st try!
