AndorSzoke
Hotfix-6 for ArchiCAD 12
Dear AC-Talkers,
Hotfix-6 is now available for all the major language versions of ArchiCAD 12. You can download the Hotfix through the Help menu/ Check for Updates command. You can find a list of fixed bugs in the Release Notes.
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
13 Replies 13
David Larrew
Update on my situation:
GSUS Tech Support called me yesterday to try to help me fix my MEP Modeler issue. After about an hour of trying their suggestions still not working. They are currently working on my issue and said that they would get back with me.
Just let me add... Wow, GS thanks for the call and attention on my issue. I guess things are happening/changing for the better at GSUS.
I'll check back later, after GS gets back with me.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
David Larrew
Update:
Well it seemed to be a WIBU key-related problem. GS overnighted a new WIBU key to see if my key upgrade to 13 had aything to do with my MEP problems in AC12. Apparently, there have been some issues with legacy WIBU keys that were upgraded to AC13 in the early stages of the version roll-out, and I was one of the early upgrades.
A new WIBU and fresh install of the Hotfix - all is well. Thanks, GS Tech Support.
AC 5.1-25 USA
Erika Epstein
David,
Glad to hear this is fixed. I had my wibu key go bad about a year ago and they did the same, over-nighting a new key.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
Has anyone experienced a significant slow down in the Layout Book after installing this hotfix? I have a team reporting considerable slow down.
