Hotfix for ArchiCAD 13 and 14
Greg Kmethy
Dear ArchiCAD-Talkers,
We have released Hotfixes today for both ArchiCAD 13 and 14. They are currently available for INT, USA and AUS language versions through the Help menu/Check for Updates... command. Other language versions will follow soon.
The ArchiCAD 13 Hotfix is build number 3826. Click here for the Release Notes
The ArchiCAD 14 Hotfix is build number 3269. Click here for the Release Notes
Both Hotfixes update the BIM Server as well as ArchiCAD. If you use Teamwork, you have to install the Hotfix(es) at the same time on the BIM server and all client computers.
Gergely Kmethy
9 REPLIES 9
Link
Ah this is the moment we've been waiting for! We can finally upgrade everyone to AC14. Thanks Greg - we'll let you know if anything goes wrong.
Link.
Link
Greg
Does this 3269 hotfix for AC14, include and supersede the IFC Add-On Hotfix Preview for ArchiCAD 14 – Build 3427 or do we need to install that separately (if it hasn't yet been installed)?
Link.
David Maudlin
Gergely:
From the ArchiCAD 13 Bug Fix List:
111491 DESIGN: Interior Elevation Ceiling Line is missing when slab is on story above.
This also needs fixing in ArchiCAD 14.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Greg Kmethy
Link.
You have to install the IFC Hotfix 3427 separately. As the build number suggests, the IFC add-on special hotfix (3427) is actually a newer version than the one included in the general ArchiCAD Hotfix (3269). If you are a heavy IFC user, we do recommend to use the special IFC hotfix.
If you have already installed the IFC Hotfix Preview, and are about to install the general ArchiCAD Hotfix, you are all set - the generic hotfix (3269) will not overwrite the newer (3427) IFC Add-On.
Gergely Kmethy
Greg Kmethy
David,
Yes, it will come in the next ArchiCAD 14 Hotfix. We have not forgotten about it, just the ArchiCAD 14 Hotfix was actually compiled earlier than the ArchiCAD 13, and this fix was not ready yet.
Greg
Gergely Kmethy
David Maudlin
Great! Thanks for posting the additional info.
the release notes says "all languages". So is it for all languages or not?
Greg Kmethy
Philippe,
We have one Hotfix file for all languages, but we do test it separately for every language, that is why it is not released at the same time through "check for updates..." . As languages are tested, we make them available one by one.
Gergely Kmethy
gkmethy wrote:
Philippe,
THANKS
