Hotlinked module with corner windows causes main file crash
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-06-22
06:49 PM
‎2023-05-25
06:20 PM
Rubia Torres
‎2005-06-22
06:49 PM
Has anyone encountered the following problem (AC 8.1 on Mac):
One of our users has a pln file with corner windows. When he moves walls with the CWs they (walls) blink for a second, then it gets back to normal. If he, however, links this file into a main file and tries to move the module around, there is more severe blinking and a crash with bug report.
If he removes CWs from the module file, the problem disappears. Tried different types of CWs (including empty opening), different Macs, deleted cache and prefs, didn´t help.
This is a relatively new project that was started in AC 8.1. I have also seen this problem in other files, but cannot duplicate it on a fresh template file so it seems like something just goes wrong somewhere in the process...
Any ideas?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-07-29 08:15 AM
‎2005-07-29
08:15 AM
Tomasz wrote:Did you replace the 8.1 lib parts with the 9.0 ones? The Corner windows have been extensively re-written, so that might be the problem ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-08-02 10:59 AM
‎2005-08-02
10:59 AM
This seems to be an 8.1 - only problem. Is it possible to use 9.0 CW´s in 8.1?
However, we are now in the process of upgrading to 9.0 and luckily the project doesn´t exhibit the same problem in the new version with 9.0 lib parts.
So it has been fixed.
Thanks for the reply,
