How I can make sketch effect in 2d?
Guys please help!
How I can make such sketch effect in 2d?
Only in 3d is sketch effect and it make plan only with lines.
Is it possible to make such for 2d?
5 Replies 5
I can make 2d with straight lines only. Is it possible to export as 2d sketch?
FOUND!
NO NEED FOR HELP ANYMORE.
David Maudlin
alex4ua wrote:
FOUND!
Would you post your solution for others?
Thanks,
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tim Ball
Instead of using 2D views, you can use a 3D view set to a suitable cut line that looks the same as a 2D view. Once you have that you can apply any type of rendering to it, including Sketch render.
Tim Ball
AC26, iMac
User since V5
Stress Co_
Another Option:
Cigraph's ArchiSketchy.
Unfortunately, it's not available as a stand alone add-on.
You must purchase the entire Suite.
Marc Corney, Architect
Red Canoe Architecture, P. A.
