How I save a Profile forever.
In the Work Environment there is the possibility to save the Profile with the pallet schemes, tool diagrams, shortcuts, etc. When I apply a profile in Archicad 19 it does not save. I apply, I record and I disconnect the archicad. When I reopen it does not have the profile active. Why?
How should I record the profile?
You save a profile for each of the sections as you seem to have done.
Then at the top of the list on the left you have the master Work Environment.
You can create you custom Work Environment and then set it (edit) to use each of your custom profiles.
There is also a button to set that WE as the default.
I made that but when I open again the Work Environment is diferente.
