How To Create A Blank Line Type?
How can I create a Blank Line Type, so I can use it for example in wood member objects that show the center line of the joists/beams. These center lines are making the drawings too messy. There are no options to turn them off. Anyway this is a nice line type to have for many other tools, to hide unwanted graphical representations.
Thanks,
Joseph
10 REPLIES 10
TomWaltz
I've never been able to make a true blank, but I have modified the dotted line type to have a HUGE spacing, which had a similar effect.
Tom Waltz
Thanks Tom, thats the direction I was going. But what the setting should be? I could go to maximum of 4.25 what ever that means, if you could help me with that. Also should it be Scale with PLan or Scale-Independent?
Thanks,
Joseph
TomWaltz
Thanks,
Joseph
I went for the maxiumum spacing with a Dash of 0. I used Scale Independent, but i don't know that it really makes a big difference.
Tom Waltz
I tried numerical value of ZERO and I ended up with a solid line but with maximum value of 4.25 they do not show up for a a5 feet length?!
Thanks,
Joseph
TomWaltz
Thanks,
Joseph
I'm not understanding that sentence. Can you give me a little more detail?
Tom Waltz
Thanks,
Joseph
I used Dash as 0 and Gap as 4.25, if I use Gap as 0 it is understood I will endup with a line.
Thanks,
Joseph
TomWaltz
Joseph wrote:
Thanks,
Joseph
Thanks,
Joseph
so is it that you are getting a solid line and you were expecting a nearly-non-existant line? Or that the line you get is dashed in a way you did not expect?
Tom Waltz
I was expecting a nearly-non-existent line and that is what I am getting now.
Thanks a Million,
Joseph
why don't yo use a solid line with pen 91 (pure white)?
