ā2022-08-22
02:49 PM
- last edited on
ā2024-04-10
01:22 PM
by
Claudius
Here are two screenshots showing the problem:
ā2022-08-22 03:24 PM
It looks like you just need to make the edges along the hip vertical.
ā2022-08-22 03:33 PM
What do you mean by that
ā2022-08-22 03:36 PM
This is how it looks in 2d. Any way to make this look a little cleaner as well?
ā2022-08-22 03:37 PM
ā2022-08-22 03:41 PM
I assume you have single plane roofs.
You need to make the joining edges of the roof planes vertical.
ā2022-08-22 03:50 PM
The vertical edges will make the plan cleaner as the top and bottom edge will be on top of one another.
Or there is an option in Project Preferences > Legacy, where you can show single plane roofs in plan as they were before we got multi-plane roofs.
i.e. you won't see the edges for the top and bottom surface, just the edge on the top surface.
ā2022-08-22 03:56 PM
Is there a way to connect them with perpendicular roof edges though?
ā2022-08-22 04:03 PM
No.
Because they are different pitches, when you trim one roof to the other, they will join with a bisecting angle.
If they were the same pitch you wouldn't have the problem because the bisecting angle would actually be vertical.
ā2022-08-23 09:01 AM
Hi.
this happens often as you change the angle of the roof, you have to trim the roof to the roof.
1. You pull out two roofs so that they cross each other.
2. Select one roof on your plan and with the selecting roof Tool pressing Ctrl click on the edge of another roof, so one edge is cut.
3. Doing the same for another part of the roof
See GIF, I do this by pressing Ctrl.
