How can I bring DWG as a reference
How can I bring DWG as a reference at the back that I can use it
with no changes...
thanx
3 Replies 3
Eduardo Rolon
If using AC11 =
create new independent work sheet
go to File-> External Content -> Place External Drawing
Use the Work Sheet as a Trace Reference
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
thanx !!!
ejrolon wrote:
If using AC11 =
This is the way I usually do it unless I need to know what layers things are on (it can be hard to tell slab edges from floor finishes from gridlines etc. on some drawings). If you do need the layers you can also xREF the drawing, which keeps the layers from polluting your file, or explode the placed drawing if you don't mind adding all of its layers.
