How can I create such corner windows?
I found this picture somewhere on this forum (can't trace back where exactly), and it shows an exactly same type of corner windows I'm trying to implement...
Any suggestions what object/parameters should I set/use in order to achieve this type of frames (frameless design)? I've been fighting with pre-set windows which feature really ugly fat brown frames which I was able to get rid of, but still nothing similar to this.
Any ideas?
Thanks a lot!
4 REPLIES 4
I recently made a glass stairwell, unfortunately I could find a window object which suited my needs, (all butt glazed frameless windows). The curtain wall feature did not have what I wanted either. So I made it will the wall tool. I made a new layer for the glass panels, and set the wall tool to 1/4" thk, then I made the panels, keeping them separated them by 1/64" so the elevation would show the individual glass panels. for the connections, I modeled one as saved it as a gdl object, then added the new object to all the panel joints.
It sounds like a lot more work than it actually was.
Hello Vytis
The object that you show is a free object from Cad3d.it —the CUMirco's site— One of the most important Italian gates multi-CAD, withy forums, links and a great "download" sections. CUMirco is the moderator of the ArchiCAD forum on this site.
This one is only accessible after a "free" registration.
You can find an archive of the Finestra continua (m) 8 ; OBJ Vetrata strutturale (m) 8; by Mirco Sorgato
here http://www.cad3d.it/modules.php?op=modload&name=Downloads&file=index&req=getit&lid=122.
Enjoy it
Brilliant! I was looking for this type of window!
Thank you very much, indeed!
Cheers.
