How can I make a window with slope?
I made two roofs because I don't know work with the ramp very weel or it works bad.
So, I made two roofs, one to make the low slab and the other roof is the upper slab. I cut the two walls with the roof and now I want to put windows in those walls.
How is it possible?
6 REPLIES 6
How is it possible?
You place the windows as you would in any wall. Getting them to match the slope of the ramps will depend on the options available in the particular window part. The curtain wall tool may work better depending on your needs.
Thank you.
I will try that way!
When I make trim to roof it trims the window but the lower and the upper frame disappears....it only have frame on lateral.
the window that I used it's original from archicad 13 (W1 casement 13) but it's indiferent what window I use, it only needs be similar to that,
Would you please post a hand-drawn sketch of what you're wanting for more clarification? Thanks.
Like this
