How can I model this using the shell tool?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2011-09-12
12:41 PM
ā2023-05-23
02:47 PM
Rubia Torres
I created this shape using a wall profile, but I cannot elevate one end (even using Objective).
I know we can elevate shells, but I cannot get a horizontal curve.
Any thoughts or ideas will be of immense help.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-12 02:54 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-13 05:50 AM
The most difficult part I found was to bring the outer edges of the curved shells together. I was wondering of you would be kind enough to show me how by connecting two of these together.
I will also talk to Encina to see why Objective does not recognize a wall or a roof as an element that can be manipulated to give a slope. The only way I have been successful with Objective is using the curved ramp object. But I cannot get that in a barrel shape.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-13 11:44 AM
The rotation point is the centre of the long axis.
All one piece and then you can free rotate in 3D to get the slope you want.
But if the end profiles are different or the long curve is not uniform then you are back to joining segments.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-13 12:25 PM
solitaire wrote:OBJECTiVE cannot manipulate standard ArchiCAD elements like walls and slabs because their properties are set by Graphisoft and cannot be extended. Only GDL objects have this capability, and consequently that is the primary focus of OBJECTiVE.
To produce your rising barrel vault, do the following (referring to the attached image):
- 1. First we need to create an object with the required shape. Draw a cross section through the vault using the Fill tool (you can copy/paste and item from the Profile Manager palette too).
2. Select the Fill, and click the menuOBJECTiVE > Component > New Profile.
3. In theNew Profiledialog, specify that the selected fill is a Section, enter a name for the new shape object, and select a library to store the object in (Embedded is usually a good choice). Click OK, and then click on the anchor point for the shape (the position that remains constant if the shape changes - the centre of the vault is a good anchor for this shape)
4. Select the new shape object in theOBJECTiVE Tool Settings.
5. Set the Geometry Method to placement by length and angle.
6. Click on the start and end positions of the vaulted roof.
7. Select the newly placed roof and click the menuOBJECTiVE > Tools > Bendto bend it to the required curve in plan.
8. Then view the vault in elevation, select it, and click the menuOBJECTiVE > Tools > Offsetto raise the end of the vault to the required height.
9. The finished shape in 3D
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-13 01:40 PM
solitaire wrote:Check these two videos:
Thanks Laszlonagy; I had done of this but I suppose I was looking for an easier way out as I had a difficult time adjusting the slope and connecting the edges of the various shells.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-14 05:11 AM
@Ralph: thanks for your time; your solution has worked and I am happy that my investment in Objective got justified. Excellent support.
@Laszlonagy: thanks for the links.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-14 08:10 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-14 09:36 AM
I tried to follow your steps, but I am extremely dumb. I could not get the barrel shaped roof that is horizontal; I can only achieve a vertical profile. What sort of profile should I create in the floor plan?
I understand that this is my lack of understanding about the shell tool so can you please point me to a video that shows how to achieve this?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2011-09-14 10:06 AM
Then it is just a matter of rotating it in 3d.
I am not sure of any particular videos except for the one in Archicadwiki (also on youtube I believe).
