How can I simple window marker?
Hi, my question is how can I remove the space between numbers when making a window marker. For example: I want 1000 x 2000 to be 1000x2000. and I want the text to be thinner.
Is there a custom window marker can be download or made? Thx guys.
9 Replies 9
I believe this is a system setting.
In the regional Settings in Windows, you need to change the thousands separator.
After that you will need to restart ArchiCAD, if I remember correctly, for the changes to take effect.
Edit: Sorry, I misunderstood your question.
So, the answer is: I believe you would have to modify the script of the Marker element to change that display format.
I see now, thanks man.
So, could anyone please tell me where I can find the marker element, and how to open it to edit? I tried looking at the folders and the library manager but not found anything. Does anyone know? Thanks
David Maudlin
erickjw:
Use the Open Object by Subtype... command, then navigate to Drawing Symbol > Marker > Window-Door(-Skylight) Marker to find the marker you want to modify. It is best to Save As... a copy of the marker with a new name so the original one is retained.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
1. Extract a Container.....in your case AC14 Library.lcf in a new folder on disk
2. Find a Window Marker....Object Library 14\1. BASIC LIBRARY 14\1.7 2D Elements 14\Marker Symbols 14\W Marker 14.gsm
3. Make a copy of it and rename it
4. Open that copy with 3NF GDLScripter (it´s quite an old program), change the GDL code
5. Save the modified Marker
http://www.3nf.com/en/Download.html#GDLScripter
David Maudlin
The problem with copying and renaming the object in the Finder/desktop is that the GUID will not get changed, leading to duplicate/missing object issues, see the GUID topic in the ArchiCADWiki.
David
Another way:
4. Open that copy in AC14......File > Libraries and Objects > Open Object > Browse for a Folder > ...your folder with AC14 Extracted Library.....W Marker 14_copy.gsm, change the GDL code
6. Select the Window and Load another Marker
Excellent! I think I have an idea of what to do now. Thanks.
I worked on it for a while, now is the problem:
1. I open the window marker's script in both AC and 3NF GDLScripter but I can't understand the GDL code so I cant make the change I want...
2.I try to load the new Cadimage DW Marker.gsm in the Window Selection Setting dialoug box. But it tells me the selected file is not a Window Marker File
Is there anyone who knows how to make the script and load it correctly?
Many thanks.
