Kamelite
How do I change the texture orientation?
How do I correct the texture glitch at the Arrow in the Picture? I Guess it has something to do With wether I Draw clockwise, or Counter-clockwise, but how do I correct it?
.Thag
Windows 10, Archicad 27,28 and 29
4 Replies 4
Eduardo Rolon
While in the 3D window go to Design Menu -> Align 3D Texture and select were you need the texture to start from.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Kamelite
Thnx!
That did the trick.
.Thag
I've found it helps if you check that the wall direction of both lower and upper storey walls are the same. Turn on "Wall and Beams reference lines" in View > On Screen View Options menu.
Dave Jochum
Oddly, I have a situation right now where roof surfaces are properly aligned in 3D, show correctly in plan, but wrong in elevation. Working on an AC17 file. Glitch of some sort. Anybody ever run into this? I haven't that I recall.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
