rgarand
How do I get my window marker off my plan and on my elev
Hi all,
I was wondering if there is a way to get my window marker to show up on my elevations and not on my plans...without losing the link to the window, of course.
TIA
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
TomWaltz
Yep.
  • 1. Set up the label you want to use for the Door/Window in the Label Tool.
    2. Go into the Elevation View, select the door/window you want to label.
    3. Bring up it's Properties Menu.
    4. All the way at the bottom, under "Listing and Labeling" check the box to "Label Door"
Hope that helps!
Tom Waltz
