How do I increase lineweights in plan and not elevation
I'm only 2 months into Archicad. I have increased a the uncut line pen for a 6" block sitting on a 12" block. I did this to make it pop in the foundation plan. However it also changes it in the elevation which is not helpful.
How do I make a lineweight change in plan only?
Thanks,
Kreg
4 Replies 4
bind a proper pen table to view that will represent plan and the different pen table to the section view.
Piotr
vfrontiers
Also.. .you can OVERRIDE PENS in the ELEVATION (or section) DIALOG.. The sad news here is EVERYTHING will have the same pen, including TEXTURES... I'd really like to see the ability to override textures separately...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Post moved to 'Working in Archicad' section.
Bruce
You could also use Graphic Overrides
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
